Using the Application Macro
Run the Create Coaxial Connector Feed application macro to create a coaxial connector on a finite substrate.
- Open a CADFEKO model where you would like to add a coaxial connector.
application macro from the application macro library in
CADFEKO.
Figure 1. The Create Coaxial Connector Feed dialog.
- In the Specify coaxial dielectric drop-down list, select the insulating connector dielectric.
In the Specify points group, specify the named points to
define the location of the coaxial connector.
Note: Point C can be any point on the surface of the substrate (it is not required to be on the edge of the substrate).
In the Specify diameter using variable or value group,
specify the following:
- In the Specify coaxial length using variable or value group, specify the coaxial length of the connector.
In the Excite coaxial feed group, select one of the
following options:
- None: No port or excitation is added to the coaxial connector.
- Edge port: The coaxial connector is fed using an edge port with a voltage source. The construction takes into account the limitation that a port cannot be placed on the boundary of a finite dielectric substrate when using the method of moments (MoM).
- Waveguide port: The coaxial connector is fed using a waveguide port with a waveguide source.
- In the Select part to union with connector drop-down list, select the model part that will be unioned with the coaxial connector.
- In the Select configuration drop-down list, select a configuration. The specified configuration determines if a global or local source should be added. The frequency of the configuration is also used to determine the edge mesh refinement.
- Click Create to run the script and to create the coaxial connector.
