Setting a Region to a Dielectric
Change the region property of the substrate to dielectric.
- In the model tree, select Cuboid1.
- In the details tree, under Regions, select Region1.
From the right-click context menu, select
Properties.
Figure 1. The right-click context menu options available for regions. -
On the Modify Region dialog
(Properties tab), set Medium
to Teflon.
Figure 2. The Modify Region dialog.Tip: Simplify workflow by usingCreate new to define items when needed.
- Click OK to modify the region property and to close the dialog.
