Using the Optenni Lab Macro with Field Data
Use the Optenni Lab: Port Matching application macro to transfer the far field data for each active port to Optenni Lab.
Execute the Optenni Lab: Port Matching
application macro.
The Optenni Lab: Port Matching dialog is displayed.
Figure 1. The Optenni Lab: Port Matching dialog showing the Run mode options.
- Select the Update the current model and generate all required data and click Next.
In the Additional data group, select the
Include far field data check box.
Figure 2. The Optenni Lab: Port Matching dialog with the Additional data group.
Click Next to create the models and transfer the field
Two models is created and executed in the same directory as dual_antenna_with_far_field.cfx with the following names:
- The dual_antenna_with_far_field.GenerateFarFieldData.cfx model creates a .ffe file for each active port.
- The dual_antenna_with_far_field.GenerateTouchstone.cfx creates the S-parameter data for the antennas.
- Follow Step 3 to Step 4 to create the matching networks in Optenni Lab and view the results.
