Matching the Antennas with Optenni Lab
Use Optenni Lab to match the antennas. Use the
application macro Optenni Lab: Port matching
From the Application macro menu, select Optenni Lab: Port matching. This
launches the Select run mode dialog.
Figure 1. Options for running the Feko-Optenni Lab link.
Note: If the first run mode is selected, a new .cfx file is created and the unmatched S-parameter simulation is executed. -
Select Use existing data for the current model and click
Next.
This sends the Touchstone results to Optenni Lab to design the matching circuit.
Generate the matching circuit by following the steps in the Optenni Lab tutorials and documentation.
Figure 2. Single band antenna matching network (Optenni Lab) and general network (CADFEKO).
Figure 3. Dual antenna matching network (Optenni Lab) and general network (CADFEKO).
Right-click in the circuit view and select Transfer circuit to
Feko and
quit.
A new .cfx file is created automatically when the matching circuit is added as a general network.
Run Feko to obtain the matched antenna S-parameter.
Figure 4. S-parameters for the matched single antenna.
Figure 5. S-parameters for the matched dual antenna.
1 The single antenna model
corresponds to Optenni Lab
Basic Tutorial Aand the dual antenna model refers to Optenni Lab
Multiantenna Tutorial B.
