Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Set a local mesh of 1.5 on the antenna arms.
Figure 1. The model face that requires a local mesh.
Create the mesh.
- Set the Mesh size equal to Standard.
- Set the Wire segment radius equal to 0.15.
- On the Advanced tab, select the Allow elongated triangles check box.
- On the Advanced tab, adjust the Mesh size growth rate slider, three notches from Slow.
