Obtaining the Dual Antenna Unmatched S-Parameters
Solve the dual PIFA antenna and obtain the unmatched S-parameters.
Follow the same steps as for the previous model.
  • Create a new CADFEKO model.
  • Import the antenna model from the %FEKO_SHARED_HOME%/installedapplicationmacrolibrary/CADFEKO/optenni/utils/dual_antenna.dxf file.
  • Use the same approach as the previous model.
  • Place wire ports at both feed pads of the dual antenna.
  • For the S-parameter request, ensure both ports are active.
Figure 1. S-parameters for the unmatched single antenna.
Figure 2. S-parameters for the unmatched dual antenna.
