Creating and Configuring the Model
Create the dual_antenna_with_far_field.cfx base model with a far field request.
- Create a new CADFEKO model.
- Import the antenna model for the dual_antenna.dxf file.
- Follow the steps in Completing the Model to create the model.
- Place wire ports at both feed pads of the dual antenna.
- On the Request tab in the Solution requests group, select Far fields.
Click 3D pattern to request a full 3D pattern.
Note: Optenni Lab requires a full 3D pattern when optimising the matching networks with far field data.
- [Optional] Increase the increment of the number of phi and theta points.
- Click Create to create the far field request.
- Follow the steps in Modifying the Auto-Generated Mesh to setup the mesh.
- Save the model as dual_antenna_with_far_field.cfx.
