Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Specify local mesh refinement.
- Set a local mesh size of d/50 on the dielectric faces on the upper most face of the geometry as well as the bottom most face.
Tip: Open the Modify Face dialog, click the Meshing tab and then select the Local mesh size check box.- Set a local mesh size of d/50 on the Glue region.
- Set the Mesh size equal to Fine.
