Parameter Type |
Description |
Value |
SFBool |
Single Boolean |
Any single Embed value |
SFFloat |
Single float |
SFInt32 |
Single integer |
SFVec2f |
Vector 2 floats |
Embed vector of two elements |
SFVec3f |
Vector 3 floats |
Embed vector of three elements |
SFColor |
Color |
SFTime |
Time |
double |
SFRotation |
Rotation |
Embed vector of four elements (x, y, z, angle) axis-angle |
MFFloat |
Multiple floats |
Any vector |
MFlut32 |
Multiple integers |
Any vector |
MFVec2f |
Multiple vectors of 2 |
n x 2 matrix |
MFVec3f |
Multiple vectors of 3 |
n x 3 matrix |
MFColor |
Multiple colors |
n x 3 matrix |
MFTime |
Multiple times |
Any vector |
MFRotation |
Multiple rotation |
n x 4 matrix |
VRML parameters have the following settings:
If the parameter is preceded by |
Then |
A red X |
It cannot be selected as a block input wire |
A green checkmark |
It has already been selected as a block input wire |
An empty box |
It has not yet been selected as a block input wire |
To select a parameter as a block input wire, highlight the
keyword and press
. The selected
parameter appears in the Block Input Wires window.
