Using vissimRequest() in a custom implicit solver
The vissimRequest() function is a general-purpose function for making requests to Embed. A user-written solver uses vissimRequest() to read and write optimization information in a diagram. The general format of vissimRequest() is:
long FAR vissimRequest(long req, long arg2, long arg3)
The first argument (long req) is a message code describing the action for Embed to take. The list of message codes is defined in VSUSER.H, which is installed in Embed-install-directory\VSOLVER. The message codes that pertain to writing a local static solver are listed in the table below.
Message code
VR_EXECUTE
Executes the diagram on iteration without moving time.
VR_GET_BLOCK_PARAMS
Returns a pointer to a block’s parameters.
VR_GET_CONSTRAINTS
Arg2 returns a vector of local constraint values. Ordering of the elements vector can be determined by the value of the ID parameter for the constraint block. Embed sorts in sequential order, from low to high.
VR_GET_SOLVER_INFO
Arg2 returns information related to the diagram and the implicit solver dialog settings in the following manner:
arg2[ 0 ] = number of constraints
arg2[ 1 ] = number of unknowns
arg2[ 2 ] = relaxation value
arg2[ 3 ] = maximum iteration value
arg2[ 4 ] = error tolerance value
VR_GET_UNKNOWNS
Arg2 returns a vector of current local unknown output values. Ordering of the elements vector can be determined by the value of the ID parameter for the unknown block. Embed sorts in sequential order, from low to high.
VR_GET_UNKNOWNS_INPUT
Arg2 returns a vector of current inputs to the unknown blocks. Ordering of the elements vector can be determined by the value of the ID parameter for the unknown block. Embed sorts in sequential order, from low to high. (This is useful for the initial condition setting.)
VR_GET_VERSION
Returns the current version of Embed.
VR_GET_VISSIM_STATE
Gets information related to the global state of Embed. The information provided is a copy of the current internal state; modifying it will not change Embed’s state. Arg2 should contain a pointer to a SIM_INFO structure, defined in VSUSER.H, which will be filled in by the vissimRequest() function. Arg3 should contain the size of this structure (sizeof(SIM_INFO)) to allow for version compatibility checking.
VR_SET_UNKNOWNS
Sets diagram unknowns based on the vector passed as arg2. Ordering of the elements vector can be determined by the value of the ID parameter for the unknown block. Embed sorts in sequential order, from low to high.
