Using ActiveX to exchange data
Embed provides the ActiveX read and ActiveX write blocks for real-time, interprocess communication. Using these blocks, you can exchange data with other applications that support ActiveX. The ActiveX read block receives data from the Active X container; the ActiveX write block sends data to an ActiveX container.
Required files
To register properly, the Embed ActiveX control requires the following files:
      MFC42.DLL
      MSVCRT.DLL
      OLEAUT32.DLL
      VSMIPCD.DLL
The first three files are in your Windows system directory. The last file is in your Embed-install-directory.
