The Data Browser lists the current variables and variable attributes for the submachine. You can add and delete variables, and update their attributes through this window.
Comment: Indicates user-specified comments.
Default Value: Indicates the initial value for the variable.
Name: Indicates variable names.
Pin: Indicates the input or output connector number on the submachine block. For State ID, it indicates the active state from the given region.
Scope: Indicates how the variable is scoped.
Type: Indicates the variable data type.
Value: Indicates the current value of the variable.
