Some blocks and commands use a text editor to view data specific to the block or command. The default text editor is Notepad; however, you can change the default with Edit > Preferences.
To set the default text editor
1. Choose Edit > Preferences > Preferences.
2. After Text Viewer Path, click Edit to select a text editor.
3. Click OK, or press ENTER.
