Simulink Category: Source blocks
Embed Block Equivalent: Repeating Sequence compound block
This block is translated; however, it requires a map file and period time. The translator automatically generates the map file. However, if arguments for the original block are complicated MATLAB expressions, the original expressions are written to a file that you must convert manually.
