You may lose a link if you move or rename a source file. If this occurs, you must redirect the link to the appropriate location or file name.
To reconnect an embedded diagram
1. Right-click the embed block, or choose Edit > Block Properties and click the block.
2. In File Name, enter the correct path or new file name, or click … to select it.
3. Click OK, or press ENTER.
