Simulink Category: Signals and Systems blocks
Embed Block Equivalent: MC II compound block
This block is partially translated; however, you must check input signal dimensions. Scalar to vector transformation produces a row vector. Usually it is not important, but matrix operations require an exact shape, either row or column, depending on the operation. See the From File command for information on using the scalarToVec block to add input connectors.
