Block Category: Fixed Point
Description: The limitedIntegrator (Fixed Point) is a fixed-point implementation of a limited integrator. This block is generally used on an embedded target that has no floating-point unit (FPU). Use the limitedIntegrator block when you are interested in only simulation and not generating code for an embedded target.
To see the implementation of the limitedIntegrator (Fixed Point) block, right-click the block.
The high and low limits are displayed on the limit block. You can set the limits in the limit Properties dialog.
The initial condition for the Limited Integrator (Fixed Point) block is set in the unitDelay block.
