Knowledge Studio Scoring
Block Category: Extensions
Inputs: The inputs are dependent on the Data Config file. This file specifies the number of inputs and input labels.
Outputs: Standard set of outputs, which can include:
     inferencetime (ms): The time taken for each input to be predicted or to calculate its probabilities.
     predictions/probabilities: Matrix output based on the number of predictions. The final sum of the output should be equal to 1 to verify the algorithm that creates the decision tree is working.
     treeNodeID: The node in which the predicted output is present.
     treeNodeNumber: The branch of the node in which the predicted output is present.
     treeNodeWeight: The weight to which tree node input belongs. The weight is used to verify that the algorithm that creates the decision tree is working.
Description: The Knowledge Studio Scoring block uses the specified C file and accompanying Data Config file to generate a DLL that can simulate the response of the decision tree. To generate the DLL, click Create DLL in the Properties dialog, then click OK.
Data Config File: Specifies the path to the data configuration file (CVS or TXT), or click to select it.
KS Generated C: Specifies the path to the C file generated by Knowledge Studio, or click to select it.
