Generating ABCD state-space matrices
Analyze > Linearize generates the ABCD state-space matrices from a nonlinear system by numerically evaluating the matrix perturbation equations at the time the simulation was halted and Embed was invoked. For a general multiple-input-multiple-output (MIMO) system, the ABCD state-space matrices contain the following coefficients to the vector equations:
generating ABCD state space
where:
A = system matrix
B = input gain matrix
C = output gain matrix
D = direct link gain matrix
state vector derivative
 state vector
 output vector
 input vector
Analyze > Linearize uses a central differencing scheme to approximate the partial derivative terms at the specified operating point. The four resulting matrices can be displayed directly on the screen or saved in an M file.
To generate and display ABCD state-space matrices
1.    Prepare the system for linearization.
2.    Choose Analyze > Linearize.
3.    In the System Linearization dialog under Output Selection, activate Linearize To Screen Display.
4.    Click OK, or press ENTER.
Four dialogs appear in succession showing each matrix.
5.    Click OK at the bottom of the dialog, or press ENTER, to close the current matrix dialog and open the next one.
To generate and write ABCD state-space matrices to an M file
3.    In the System Linearization dialog under Output Selection, activate Linearize To MatLab File.
4.    In the Result File box, specify the name of the M file to which the matrices are to be written. When you select this parameter, enter the complete pathname for the M file. The following default specifications are used for the parts of the pathname that you omit:
If you omit
This is used
The disk drive
C:
The directory name
The directory from which you opened Embed
The file name
VABCD
The file extension
M
5.    Click OK, or press ENTER.
Linearize writes the matrices to the specified file that can be read into MATLAB or Altair Compose.
To select reference points
3.    In the System Linearization dialog, click Select Input/Output Points.
The pointer becomes a crossbar.
4.    To select an input reference point, click over the output connector on the block that produces the signal with which you want to linearize.
The output connector changes color. If the connector you select is invalid, you hear a beep.
5.    To select an output reference point, click over the input connector on the block that consumes the signal against which you want to linearize.
The input connector changes color. If the connector you select is invalid, Embed beeps.
6.    Click over empty screen, at least  from any block to exit this mode.
