When an orthogonal composite state is entered, each one of its regions is also entered, either by default or explicitly. If a transition terminates on the outer edge of the composite state, then all the regions are entered using default entry. If the transition explicitly enters one or more regions (for example, in case of a fork), these regions are entered explicitly and the others by default.
