You can embed existing objects from files or insert new blank objects and create the information right in your diagram.
To embed an existing Mathcad document
1. Choose Tools > Import > Insert Mathcad Object > From File.
2. Find and select the Mathcad document (MCD) you want to embed in your diagram.
3. Click OK, or press ENTER.
To embed a new Mathcad document
1. Choose Tools > Import > Insert Mathcad Object > New.
2. Embed opens a Mathcad window in which to create an embedded Mathcad document.
3. Create the document. For information on using Mathcad, see your Mathcad documentation.
4. Click outside the Mathcad document to return to Embed.
