Using the vsmCgRuntimeCommand
This function runs the simulation using the specified input signals.
int vsmCgRuntimeCommand(
              IN SIM_STATE * hSim,
              IN int cmd,
              IN double inSig[],
              OUT double outSig[]
              INOUT double * targetTime);
Command values
RTE_RUN_TO_TIME  Runs the Embedmodel until *targetTime is reached. InSig contains a vector of double precision inputs to the simulation. Note that the order of the inputs is the top-down order of the original compound block connectors. On return, outSig contains the calculated output values.
Return values for RTE_RUN_TO_TIME
VSM_SIM_MATH_ERR  Indicates that a math error has occurred.
VSM_SIM_END_TIME_EXCEEDED  Indicates that *targetTime is past the current Embed end time.
VSM_SIM_USER_STOP  Indicates that a user has pressed the stop button or that the stop block has been actuated.
VSM_ERR_FILE_ACCESS  A map or import file could not be opened.
RTE_SET_EXIT_CONDITION  Takes the string in inSig and sets it as a C expression to be evaluated at each time step for early simulation termination.
RTE_SET_TIME  Moves Embed time forward to *targetTime. Note that blocks do not calculate during this call.
RTE_GET_TASK_TIME  Fills *targetTime with the current Embed time.
RTE_GET_TIME_STEP  Returns the current Embed time step.
RTE_GET_NEXT_TIME  Returns the next time at which Embed calculates new values.
