The Get Target Stack and Heap command displays the stack and heap used on the target.
Connected to part: Displays the connected target. If you are not connected to a target, a question mark (?) is displayed.
CPU Speed: Indicates the speed of the CPU.
Heap Used: Indicates the heap used on the target.
Multiple of Crystal Freq: Indicates the multiple of crystal frequency.
Stack Used: Indicates the stack used on the target.
