Similarities and differences between 16-bit and 32-bit TI DMC block
Most of the 16-bit Texas Instruments DMC blocks use 1.16
scaling, which means you use inputs between -1.0 and 0.9997. Most of the 32-bit
Texas Instruments DMC blocks use 8.32 scaling, which means that you use inputs
between -256 and 255.99999.
