Time Simulation Tab
If romAI is used to generate dynamic ROMs, it is important to have a tool that easily performs preliminary time simulations to assess the accuracy of the transient behavior after the romAI model has been trained.
The Time Simulation tab has been designed to perform these time simulations in just one step.
Use the Import
icon to select a dataset file, if not already
selected. The selected dataset file name can be seen in the file name info section at
the bottom of the dialog box.
Note: The format and labels in the
dataset file are the same as those in the training file.
A time simulation is triggered. After the simulation runs successfully, the plot is updated.
The following are drawn in the plot:
- Blue line: The dynamical results produced by the romAI model, given the inputs and the initial state conditions that are contained in the dataset file.
- Green line: The target time history.
- RMSE Metric: Root Mean Square Error calculated between the two signals is shown
in the legend. Note: The RMSE is calculated for the segment and output currently active.
Use the list box to select the output of the romAI model that you want to plot.
If the loaded dataset file contains multiple time histories, you can select the desired history in the segments list box beside the output list box.
