Instance Evaluation Tab
romAI can be used to generate static ROMs.
In this scenario, a time simulation is not meaningful, and it is replaced by a classical inference operation over the loaded dataset. Also, the tab name changes from “Time Sim” to “Instance Eval.”
Repeating the same steps as before, the following scatter plot is generated for a static ROM:
  • Blue dots: The static results produced by the static romAI model, given the inputs contained in the dataset file.
  • Green dots: the target results.
  • RMSE Metric: Root Mean Square Error calculated between the romAI and dataset instances.
    Note: RMSE is calculated for the segment and output currently active.
