Generate Hyper Planes
  1. Select the 1st and 2nd inputs from the Inputs/States menu for the x-axis, y-axis, and one output from the Outputs menu for the z-axis.
  2. Specify the range of the x- and y-axes using Compose OML syntax.
    The x/y grid is automatically created for the hyper plane. All other inputs and states are held constant.
  3. For each additional input and state that you want to include, you can specify the constant value for each through the menu and the slider.
    After you have specified the values for all the inputs and states, the hyper planes are updated automatically.
    The axes are labeled with respect to the names of the selected inputs and states and output.
