Web Interface is not Responding
- The vovserver is down.
- The vovnginxd daemon is down.
- DNS is not configured to allow a route to the Monitor server host.
- A firewall may be running that is blocking access to the Monitor server port (5555 by default).
- If the Altair Accelerator installation or the licmon.swd is located on a network share, verify that the share can be reached from the Monitor server host
