Set Up My Views
To set up your own view, perform the following steps:
From the Views tab, select the My
View option.
Figure 1. My View
- Enter a name for your view and click Create New View.
Enter a filter name and then select from Tags or
Features list.
For example:
- Filter Name: Enter a filter name.
- Tags: Enter an actual tag name, such as BUILT_IN or a tag pattern (or a tag pattern match).
- Features: Enter a feature, such as AEMv8_RAVEN. For pattern matches, both the ? (single character match) and * (multiple character match) wild card characters are supported.
- Repeat this process until you have defined as many filters as you like.
When done, click Finished Editing.
You will then see the All View page.
- To set your new view as the default view, click Set as Default.
