Set a Default View from Existing Views
If there is no default view specified and others have set up views, you can set up an existing view, as the default view. To do so, perform the following steps:
Go to the Views tab and select the All
Views option.
This shows a list of all views that have been created, and by whom.
- Select a View and in the Actions Column, click Set as default.
Return to the Home tab.
The default view you have chosen will display.
