Rename a Tag
To rename a tag, perform the following steps:
- Go to the Admin tab, and select the Monitors tab.
Scroll down to the bottom, find the tag that needs to be removed, and select
Edit.
Figure 1. Renaming a Tag
- Change the name of the tag name and click Update at the bottom of screen.
- You need to delete the tag you just renamed from two different places. Go to the Admin tab, and select the Tags tab and then Server.
- Ensure that the top left of the page says, "Tag Administration (server)" and NOT "Tag Administration (database)" or it will delete the tag from the database.
- Click the checkbox by the Tag you wish to delete.
- Click the Delete Selected Tags from Server Memory button.
Go to the Admin tab and select the
Tasks option.
The Periodic Job List will display.
Figure 2. Tasks
- Find the ".info" and ".stat" jobs for the tag of your choosing.
For each of the jobs, click on the Job name (highlighted in blue).
The Admin Job page will display.
Figure 3. Job Admin Page
- In the upper right corner, click on the trash can icon to forget the job.
- Click Confirm.
