Remove a Tag
You may want to edit or remove tags that were created to a monitor a license server.
Note: Any name change will only change the name going forward; it will not change any historical data. So, if the tag changed was cad_WAN_SC and is changed to cad_WAN_AUS on Jan 1, 2023, you need to use the old name to pull reports prior to that date.
To remove a tag, perform the following steps:
  1. Go to the Admin page, and select the Monitors tab.
    Figure 1. Add a Monitor
  2. Scroll down to the bottom of the page and find the tag that needs to be removed, and click Delete.
    A new window appears.
  3. Go to the Admin tab, and select Tags > Server.
    Note: Ensure that the top left of the page says, "Tag Administration (server)" and NOT "Tag Administration (database)​" or it will delete the tag from the database.
    Figure 2. Tags - Server
  4. Click the check box by the Tag to delete.
  5. Click Delete Selected Tags from Server Memory.
  6. Go to the Admin page and select the Tasks tab.
    The Periodic Job List will display.
  7. Find the ".info" and ".stat" jobs for the Tag of your choosing.
    Figure 3. Tasks
  8. For each of the jobs, click on the Job name (highlighted in blue) and the Admin Job page will display.
    Figure 4. Job Admin Page
  9. In the upper right corner, click on the trash can icon to forget the job.
  10. Click Confirm.
