Sample a License Server
- Go to the command line (right-click start menu and select Command Prompt Admin).
Enter the path to installation under the extraction directory.
- Type cd win64\bat\
- Type vovinit
This initializes the command prompt with Altair Accelerator software and enables the shell command prompt and checks that the rlmstat – that is running is VOV. -
Sample a license server.
It will show that the system is running.
- Verify the system is working. If the port doesn’t exist, you will get a message indicating that.
