Change the Sampling Period for One Instance
To change the sampling period, perform the following steps:
- Go to Admin tab and the Monitors option.
Scroll down to the last section, Section 8 Periods.
Figure 1. Admin Page – Monitor Option
- Change the timing of the Usage sampling option to the desired minimum.
