Configure a Batch Report
Combine data and create static reports.
These instructions describe how to configure a batch report as an administrator.
To create a batch report, go to the History menu and
select Batch Reporting.
Figure 1. Create a Batch Report - Admin View
Select from the following options:
- Time Range
- Specify the time range of the report.
- Filters
- Select types of filters you wish applied to the report. Current tag, feature, user, host, project, and version filters are available. User groups will also show up as filters.
- User-Specific Batch Reports
- If this option is selected, choose from the list of known scripts. If no scripts are shown, contact customer support.
- Output Format
- Choose between generating an HTML or CSV report, or both. If CSV is selected, only tabular report components will be available.
- Report Components
- Select multiple reports if you want to compare data. For example, you might want to compare company checkout statistics with denial statistics.
- Table Row Limit
- Specify the max number of table rows to display for statistics report components.
- Features Options
- Specify whether to break down results by feature.
- Data Source
- Specify whether data comes from Monitor stats samples, debug logs or from both.
- Report File Options
- Specify whether report output should be placed into a single file, or whether it should be split up by tags and placed in multiple files (per tag).
- Report File Name
- Specify name of report output file.
- Static Images for Plots
- Contains reference to static images which were created in the working directory.
When done, click Create Reports.
Your reports will automatically be generated when you click on the Batch Reporting option.
- Refresh the page to get updated status of the report generation.
- To generate CVS file from the report, view the report and click CVS at the bottom of the table.
