Configure a Notification
To configure the default notifications that come with Monitor, perform the following steps:
Go to the Admin tab and select .
The following page will display:
Figure 1. Admin Tab - Notification
This displays all the following notifications; they have default values, which
can be changed.
- CheckAlerts
- This sends an email if there are active alerts in Monitor.
- CheckDownLicDaemon
- This sends an email if Monitor has lost a connection to a server that it is monitoring.
- CheckDownSlaves
- This sends an email if any of the taskers are down.
- CheckVendorLicenseExpiration
- This sends an email if when license is going to expire. The default is 10 days before expiration.
- Daemons
- This sends an email if the daemons are down.
- LicenseNearSaturation
- This sends an email if the feature is nearly fully utilized; the default is 95 percent – that implies that 95 percent of the feature is being used.
- LongCheckouts
- This sends an email if there is a checkout longer than 30 days.
- ServerDiskSpace
- This sends an email if available disk space is below 1%.
- ServerSize
- This sends an email if the size of the server increases by 1.5 times.
Click Edit for a specific alert.
A new window displays.
- Optional: Click Disable, to disable the notification.
From Notification Configuration page, you can change the
following items:
- Check Frequency
- This sets the frequency of the health check.
- Mail Notification Frequency
- This sets the frequency for the notification.
- Recipients
- This is the list of owners who will receive notifications. Add emails and separate them by a space.
- Options
- The options are shown under the documentation section of this page, and you can enter in changes accordingly here.
- Click Change to save your changes.
