Set Up Monitor as a Service – Windows Only
Once the Monitor system is set up and installed, it is recommended that Windows users set up a Monitor as a service. This enables you to more efficiently manage Monitor and to log in from your local host easily.
Stop Monitor from running by clicking
Stop.
Under Windows Services, enter in your account and password.
The service account name is generated from your company, as is the password.
- Click Install.
When finished installing, click Start from the Windows
Services area.
You can log in from the local host from this point forward.
