Request a License File
After setting up the system, you should request a license file.
Complete the following steps.
In the web interface, click .
Figure 1. Licensing Page
- Scroll down to Request a License for This Host. Follow the instructions to request a license or contact your sales rep. The license will be mailed to you as a text file.
- Open the file. Save the license file under the licmon.swd directory, (c:/altair/swd) which can be found in the executable window under the Working Server Directory.
- Rename the license file to license.key. If a prompt comes up asking you to confirm the change in file type to key, confirm the change.
- Go back to the web interface and click .
Click Re-Acquire all Licenses.
Figure 2. License Status
