Recommended Monitor Hardware Setup
Depending on your system and the number of expected checkouts, your hardware setup will vary. There are many factors; please review the following information and if you have further questions, contact customer support for a comprehensive explanation.
| Resource | Checkouts | ||
| 100,000 | 1,000,000 | >1,000,000 | |
| CPU (x86, e.g. Intel Xeon) | Dual Core Server Class | Quad Core Server Class | Quad Core Server Class |
| Memory | 1 GB | 8 GB | 16 GB |
| Disk | 5 GB | 50 GB | 200 GB |
| Server Working Directory | NFS or Local | NFS or Local | NFS or Local |
| Database | Local Disk | Local Disk | Local Disk |
Expected System Environment
The Altair Accelerator products are built to run on a well-conditioned
network. This outline gives an overview of what is expected to be in place.
- All participating hosts are networked.
- The host clocks are well-synchronized (e.g. via NTP).
- Naming services are functional and fast
- User/Group account names and UIDs are uniform on all machines
- Resolution of hostname works (DNS or NIS).
- Reverse DNS lookup works (get host name from IP address).
- There is a remote-shell capability for at least the product administrator's account to all participating machines. If not available, use the example .bat files as a guide to create a script, and place it in the appropriate directory. Example startup files are provided in $VOVDIR/etc/boot. Choose the one that best fits your scenario.
- There are networked file systems on which to place shared files, so that
they can be accessed from each machine, using a local path enabled by the
NFS. The shared files include:
- Installed Altair Accelerator software, including at least one branch that must be writable (the local directory).
- The Server Working Directory (.swd)
- The users' home directories.
- Work area for each project.
- Standard directories, binaries and libraries are available, including the
following:
- /tmp exists
- /usr/tmp exists
- gcc libs are installed (libstdc++, libfcc_s)
- libXScrnSaver RPM, which installs library “libXss.so.1” should be available on Linux in order for vovxidle to work appropriately.
- libXft-devel
