Enable Monitor to Detect Short License Checkouts
If a given license checkout is not showing up in your checkout history report, it could be due to the timing of the sampling period. By default, Monitor uses a sampling period of 30 seconds to check the status of each license. To detect license checkouts less than 30 seconds, change the sampling period.
