Standalone Configuration for Parsing Debug Logs (Web Based)
To set up Monitor for standalone configurations, perform the following steps:
Go to the Admin tab and select
Monitors.
Figure 1. Add a Monitor
Enter the full path to the status command, if needed
- Select the Monitor Type.
- Specify a unique tag name.
- Enter the license file location.
- Enter the full path to the status command, if needed.
Enter path to debug log (use the
@DATE@.nameoflog) note that for either key word to work the date must be in the formatyyyyMMDD. - Enter the Time zone, if different from that of the Monitor server.
- Optional: From Options, you can click If parsing a debug log, load checkouts in additional to denials. Click this ONLY if you don’t have live sampling. We don’t recommend this.
- Select periods. Default periods can be changed, but we recommend you keep the defaults.
- Click Add New Monitor.
