Joint Configuration for Parsing Debug Logs (Web Based)
To set up Monitor for joint configurations, perform the following steps:
- Go to the Admin tab and select Monitors.
Scroll down to the Edit Monitors section, select a monitor
and click Edit. If you don’t see the Edit option, go to
the File Configuration section.
Figure 1. Add a Monitor
- Click the Update <Tag Name> button.
Enter the path to the debug log (use the @DATE@.nameoflog)
Note: For either key word to work, the date must be in the format
yyyyMMDD. - Enter the Time zone, if different from that of Monitor.
- Click Update <Tag Name>.
