Add an Agent via an SFD
There are two Single File Distributables with distinct use cases.
- lmagent SFD
- This SFD is the actual agent. It will connect to the Monitor specified in the SFD form/options.
- vovtsd SFD
- Not an actual agent. It is the "VOVTaskerServiceDaemon" that is used to start and stop agents remotely using the agent web UI mentioned in the "Add and Configure an Agent using the Web GUI" section.
