Links
By default, no links will show until you have configured them. You can add links to your Home tab to more efficiently manage your system, and we recommend you do that once you have configured the system.
You must have Admin permissions to perform this task.
To add a link, go to the Admin menu and select the
Links option.
Figure 1. Add a Link
- Type in the link name and add a URL.
Click Create Link.
When you return to the Home tab, Links will show this as option.
To delete the link, return to the Admin tab and select the
Links option.
Figure 2. Delete a Link
