VOV CGI Procedures
This document describes the Tcl procedures provided by VOV for creating HTML pages using CGI programs. CGI (Common Gateway Interface) is a way of using external programs to dynamically create pages which are returned by your project's vovserver to a user's web browser.
- Writing the CGI script as a Tcl script;
- Using the VOV procedures described in this document
The CGI programs may be written in any language which can produce an executable program that makes text output.
General-purpose web servers such as Apache and Microsoft IIS support different languages such as Perl, Tcl, Python, Php, Visual Basic and C. The VOV server can also use a CGI programs written in any language, but it is best if your CGI scripts are written in Tcl, because then your programs may use the vtk_* Tcl API functions to interact with the vovserver.
HTTP/1.0 200 OKContent-Type: text/html
Content-Length: the length of the HTML pagetext of the HTML pageContent-length: is required for the
HTML to be correctly displayed. When using the VOV CGI procedures, you will not need to be concerned with this type of detail. The VOV CGI procedures help you create the text, and automatically compute the proper length, and close all tags correctly.
HTML is a hierarchical language, where the various types of tags may only appear in
certain contexts. For example, it is an error to use the <LI>
(list item) tag outside the context of a <UL> (unordered list)
or <OL> (ordered list). Each tag <TAG>
defines such a context, and must be properly closed by the corresponding
</TAG> for the HTML to be correct.
In practice, modern browsers attempt to present even incorrect HTML, so that many
simple tags like <P> and <LI> do not need to
be closed properly. For tables, however, closing the tags properly is essential for
correct presentation. The VOV CGI procedures take care of this chore for you. The
scope of each tag begins with the tag's procedure, and finishes with the final
closing brace }.
VOV provides procedures to handle a subset of the tags available in the HTML specification, but this set is sufficient to quickly build informative, dynamically- created web pages about your project.
VOV CGI Procedure Overview
| Procedure | Descriptions |
| VOVHTML_START | Begin a new HTML page |
| VOVHTML_FINISH | Finish the current page |
| OUT | Insert text in page without newline |
| OUTLN | Insert text in page with newline |
| HTML | Build the HTML part of the page |
| TITLE | Set the page title |
| BODY | Build the main body of the page |
| COLOR | Set color of text |
| FONT | Specify font of text |
| SPAN | Build a span element |
| FORM | Begin an HTML form for user interaction |
| SCRIPT | Insert script code (e.g. Javascript) into page |
| OPTION | Build an option element |
| SELECT | Build a select element |
| VOV_SET_COOKIE | Set a cookie |
| VOV_GET_COOKIE | Retrieve a cookie's value |
| TABLE | Start a new table in the page |
| TR | Start a new row in the current table |
| TH | Insert a table header cell in the current table row |
| TD | Insert a table data cell in the current table row |
| HREF | Insert a hyperlink into the page |
| BR | Begin a new line |
| HR | Insert a Horizontal Rule into the page |
| H1 | Format text as Header1 style (most emphasis) |
| H2 | Format text as Header2 style |
| H3 | Format text as Header3 style |
| H4 | Format text as Header4 style |
| H5 | Format text as Header5 style |
| H6 | Format text as Header6 style (least emphasis) |
| Other Formatting Items | Format text bold, italic, etc. |
Example CGI Scripts
- Example -- Basic "Hello, World" CGI script
- This script exploits a difference between the handling of comments in
the Tcl language, and C-shell to produce an executable script written in
Tcl. The C-shell starts, using -f to specify not reading your ~/.cshrc
file, and then immediately executes the VOV 'vovsh' program, which is a
Tcl-language shell. That program then receives the remainder of the file
as a Tcl script. The Tcl interpreter sees the 'exec' line as a comment,
but C-shell does not, and executes it.Note: The -*- on either side of the word 'Tcl' allows Emacs to recognize the file as a Tcl script.
- Example -- Retrieving VOV Project Information
- You can use VOV's Tcl API vtk_* procedures to get information from your project's flow. A nodeid is an integer which is VOV's internal database ID for an object.
