Tasker Compatibility
When a job becomes eligible to run, VOV places it on the fastest vovtasker host which offers all the resources requested when the job was submitted. The Tasker Compatibility page in the web browser UI shows details of a job's compatibility with each vovtasker machine. You can use this page to understand why a job seems stuck.
Access the Tasker Compatibility Page
The Tasker Compatibility page is specific to a particular
job. You may access this page from two places:
- The more link next to a job on the Job Queue Buckets page. This is the rightmost column, and has a magnifying glass icon.
- The Tasker Compatibility link on the Job Details page.
The Job Queue Buckets page is the panel that is displayed when the Queue Buckets tab is selected in the VOV Monitor window.
Tasker Compatibility Page Description
The page consists of a table, with a row for each vovtasker
machine. The column headings are:
- Row number
- Tasker
- vovtasker name, link to details page of that machine
- Info
- Compatibility with this job
- Missing Resources
- Additional resources needed to enable this job to run
There is a button at the page bottom which returns you to the Job Queue Buckets page.
Info Field Meanings
machine.
- Busy
- Machine is responding to a server message
- Full
- All job slots have running jobs
- Suspended
- No jobs may run; not in available time band, or being used interactively
- Overloaded
- Not accepting new jobs; load average exceeds MAXLOAD in config file
- Sick
- Server has not received timely heartbeat
- Paused
- Tasker has been paused by an external signal
- Not Connected
- Tasker object is not yet connected to a vovtasker process
- Tasker Mismatch
- Resources provided by this tasker do not match resources requested by the job
- Exhausted Resource
- All of the resource are in use
- Resource Cycle
- Resource map entries form a loop
- Insufficient time left
- When using Offhours, expected job duration would extend into offline period
- Unknown
- Unspecified reason
