Rerun from the Command Line Interface
From the CLI, you can request FlowTracer to run with the command vsr.
You can request a run to a given file with:
% vsr fileName_or_VovIdYou can run all jobs associated with a directory by using:
% vsr directoryNameYou can target an entire set to be run
with:
% vsr -set setNameAs a special case, you can run everything in the whole design. Use the private set
System:nodes with:
% vsr -all
