Rerun from the Browser
When visiting a page for a set of nodes, you can start a run using the Run bar. The bar allows you to select priority and flags.
To access the Run bar, from the Project Home page, click the Jobs link.
Figure 1. The Node Set Page has a Command Bar with a Button to Request a Run
If you are visiting the page for an INVALID job, then you can start a run by clicking on the Run icon. This always starts a normal run at normal priority.
You can get a list of all active run requests by browsing retraces.
