Rerun the down-cone of a File (kicking a file)
If you change a file and would like to run all jobs that are affected by the change,
use:
% vsr -kick name_or_VovId_of_changed_fileYou can get a list of all active runs with the command:
% vovshow -retraces
ID DESCRIPTION USER SIZE MESSAGE
014435890 tmp:retrace:set:tmp:UserSelect john 2
014435949 tmp:retrace:set:System:nodes andrea 1321
014435969 tmp:retrace:set:System:nodes andrea 1322
