Regular Expressions in Selection Rules
The operators ~, !~, ~~ and !~~, which perform string matching, operate with regular
expressions (Tcl 8.0). These expressions use the ed syntax. For a complete
description of the syntax, invoke one of the following commands:
% man -s n regexp
% man ed
The following is a short summary of the syntax for regular expressions.
- The period "." stands for any character.
- The asterisk "*" stands for zero or more repetitions of the previous expression.
- The plus "+" stands for one or more repetitions of the previous expression.
- A backslash \ can be used to escape a literal period, asterisk or plus sign.
Examples
The regular expression ".*" matches every string (any character repeated any number of times).
If you want to make a set of all the files whose name contains .std., specify the regular expression "\.std\..*", in which "\." matches the period.
